How to Change Drive Letter in Windows 11
Changing a drive letter can be useful when you encounter drive letter conflicts or want to reorganize your storage structure. Follow these steps to change your drive letter safely.
Step 1: Open Disk Management
Right-click on the Start button and select Disk Management from the menu.
Step 2: Change the Drive Letter
  1. Locate the drive you wish to modify in the list.
  2. Right-click on the drive and select 'Change Drive Letter and Paths...'.
  3. Click the 'Change...' button.
  4. Select a new letter from the dropdown menu.
  5. Click OK and confirm the warning message regarding software paths.
Troubleshooting: Fixing Broken Shortcuts
Changing a drive letter can break existing shortcuts or software paths. If your programs stop working, follow these steps:
If you encounter an error where a shortcut no longer points to the correct location, follow these steps:
  • Right-click on the broken shortcut and select Properties.
  • In the Target field, update the path to reflect the new drive letter.
  • Example: If the path was D:\Folder\App.exe and you changed the drive to E:, update it to E:\Folder\App.exe.
If the issue persists with installed software, you may need to reinstall the application or manually update the registry paths, though updating the shortcut target is the most common fix.
